Here is what I have collected over the years and maybe it will help someone else.
There are so many and several are too large to upload as attachments, so see any thing you need just shoot me a PM and your email and I will get them on the way to you as fast as I can.
Repair Manuals
50cc to150cc service manual For Tank Motorsports.pdf
linhai-atv-service-manuals-linhai-300-parts-manual.pdf
1986 CH250 ELITE service manual.pdf
Charging and ignition systems for atvs.pdf
Dinli-501-PARTS-DINONP.pdf
Dinli-601-Parts2003BEAST-DIAMONDBACKNP.pdf
Dinli-DL-5015erviceManual.pdf
Dinli-DL-502PartsManual.pdf
Dinli-DL-5025erviceManual.pdf
Dinli-DL-503PartsManual.pdf
Dinli-DL-601,DL-603ServiceManual.pdf
Dinli-DL-603PartsManual.pdf
Dinli-DL-604PartsManual.pdf
Dinli-DL-701PartsManual.pdf
Dinli-ServiceManual-150ccATV.pdf
DTE150-2-150cc.pdf
GY6_Top_End_Rebuild.pdf
Leopard-parts.pdf
Linhai_260servicemanual.pdf
Odes-400-Repair.pdf
Roketa-ATV-10(ATV-DO43)-Repair.pdf
Roketa-ATV-11(ATV-D037)-Repair.pdf
SLA-120-PARTS.pdf
SLGK-110-PARTS.pdf
SLGK-150R-PARTSMANUAL.pdf
SLGK-400R-PARTS.pdf
SLU-500-600-700-PARTS.pdf
slu700db-700UTV-Service-Manual.pdf
tao-tao-atv-parts-cylinder-rebuild-kit-for 90cc-100cc-110cc-engines-p-13331.pdf
Trouble Shooter Guide for battery DRAINED Chinese Engines.txt
Trouble Shooter Guide for NO-COMPRESSION.txt
Trouble Shooting No Crank.txt
Troubleshooting.pdf
YX125CC BREAKDOWN.pdf
_________________________________________________________________________________
50 to 150cc GY6 Shop Manual.pdf
Arrow 150 Engine Service Manual.pdf
Eton Shop Manual YXT-150.pdf
GY6 Shop Manual.pdf
Yerf Dog Spiderbox GX150 Service Manual.pdf
I have put all of the wiring diagrams into a single PDF file to make life a little more simple and for some reason there was a 97 kb limit on .zip files this time and it was 30 mb in my first post.
Here is what is included:
Wiring Diagrams
PIRANHA150CC ENGINE DIAGRAM.pdf
ROKGK-01--KTR-150A--WIRING.pdf
ROKGK-11--KSX-90--wlRING.pdf
ROK-GK17--KTX-110--WIRING.pdf
ROKGK19---KTB-250W---WIRING.pdf
ROKGK-28W--WIRING.pdf
Troble Shooting No Spark for 5 PIN CDI Only.txt
Wiring Colors That Dont Match Up Help.txt
YUN BA Alarm/Remote Start/Remote Kill Install and Wiring Guide
Yun BA Remote Start Guide.pdf
All Wiring Diagrams.pdf
50cc to150cc Service Manual For Tank Motorsports.pdf
1986 CH250 ELITE SERVICE MANUAL.pdf
DTE150-2-150cc.pdf
Leopard-parts.pdf
Odes-400-Repair.pdf
SLA-120-PARTS.pdf
SLGK-110-PARTS.pdf
SLGK-400R-PARTS.pdf
Trouble Shooter Guide for BATTERY DRAINED Chinese Engines.txt
Troubleshooting.pdf
GY6 Shop Manual.pdf
GY6 Shop Manual.pdf
First time on the site. Glad i found it. I see you have a pdf. For a Odes 400 atv. Is there a possibility in getting a copy. Thanks in advance.
  • 11 months later...
thanks to all members like colt that can share info . our two youngest have been working hard to get an atv and have come up with two 110 cc chinese machines that we are rebuilding
  • 4 months later...
  • 5 months later...
In my experience alot of the time the parts will end up costing more than a Japanese bike, and the don`t last very well at all.
Most of these bikes are thrown away once they fail, try an get parts from other ppls dead bikes if possible.
  • 3 months later...
  • 3 months later...
  • 5 months later...
Hi I have a tao tao 250cc quad the first owner started the wiring and they got a replacement harness have got the bike off then an i have put the harness in every thing works but what is happening is when the coil flat blade terminal is put on the signal from cdi to coil is lost then in plug coil an spark is back can you shed some light on why it's doing this
Hello, my name is Tony and I'm new to this forum.  I have several atv's ranging from a little 50cc 2 stroke to a klf-300 4 stroke shaft drive. I'm currently looking for the repair manual/wire diagram for a 2010 taotao ATA125-E 4 wheeler with the remote kill system. Any help with this would be greatly appreciated. thank you in advance.
Hello
Newbie here.
I have a Odes 400 atv and would also be interested about this Odes-400-Repair.pdf file. Is there a possibility to get this?
greetings from Finland
  • Admin changed the title to Chinese ATV User, Service, Parts & Wiring Diagrams
On 7/24/2018 at 1:53 PM, Marcus Ransom said:
I need help with working diagram on a roketa 200cc quad the ignition key is gonna and some of the wires have been cut
Here is a wiring diagram it should be for your machine if not it will be close. There is only 4 wires going to the switch. The red dashed on print I believe will be a red white striped wire which is positive 12 volt (terminal Batt). The red wire is the kill wire(terminal HO). Green dashed or green white goes to ground(terminal E) Then the black wire is the ignition wire(terminal IG).
With switch on position contact is closed for the terminal Batt and terminal IG giving power to the CDI unit. The terminal E and HO is open.
With switch in Off position the terminal Batt and IG is open and the terminals  E and HO is closed turning the CDI off.
  • 6 months later...
On 10/7/2021 at 1:56 PM, Crawdaddy said:
Ressurrecting this old thread.  Anybody have a manual for a chinese 250cc ?  I've got a 2006 Lifan (lf250st-2 I think), and I can't find information anywhere.
Yeah I'm in the same boat, 250cc with a pair of harnesses that I cant figure out. Really vague wiring "diagram" that came with it.
  • Admin unpinned this topic
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
