2007 Honda Rancher - EFI Troubles
My son has 2007 Honda rancher 420 with fuel injection. We just got it out of the shop for several repairs. Now sometimes it will not start but the fuel injection light blinks and then you come back later and it fires up he can ride for a while , park it and then it will start again and again but by the end of the day it will not start again. The fuel injection light stays on while he is riding. I am hoping that it is something maybe I can fix without having to take back to shop again. Any help would be appreciated. When he rides he does fine just every now ang again it will not start.
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By bob2007
    • By semicolon
    • By HoldenBoy
