I have a 2000 LT250 that I recently had to replace the key switch due to the loss of the original keys. Now I can see smoke coming from in front of the gas tank. I took the cover off from around the handlebars trying to see where it was coming from. I touched a small box that was so hot it actually burned my fingers. I disconnected the battery but I can't get to the box without taking off the rack and the front fender. My owners manual does not tell my what this is. It has 5 wires running to it (3 yellow, 1 brown & white and 1 red) it appears to be bolted to the frame in front of the gas tank just below the handlebars with 2 bolts. Can anyone help me with this? I added a couple of photos to show the item I"m talking about. Thanks in advance.
Edited by RLD1
Add Photos
    • By Tim Keiper
    • By Trent Finnessey
    • By Randomnumber73
    • By TravisM
      2001 bayou 220 KLF220A
      I'm at a loss here. Thanks.
