By BuckBilly
By Sportsman500guy
By Gwbarm
IMG_4910.mov There is some slack in there but most is taken up by the gear cover,if anyone with history with these machines has had the same problem, let me know your findings. Where i am now im looking for finding replacement honda gears on Ebay and try those. I suspect the original was replaced with aftermarket gears years ago and they just worse quality as the years go by.
By Gwbarm
Just aquired this Honda 4514. I had heard of them and seen them but had never really looked at one. Amazing machine from the 90s.
It has a 14 HP inline 2 cylinder engine. A cute little fan like the old school cars had and a little radiator. It has a timing belt on the back of the engine running the cam and a water pump. Just like a miniature car engine with electronic clutches to turn blades on and off. Pretty hight tech for the 90s not a small thing and built like a tank weighs in at 600 pds hydrostatic trans. I have found out that almost anything you have to do to it the engine has to come out starter timing belt water pump. Very expensive parts i think most got junked for that reason, i did find out they were built by John Deere except for the honda engine.
Does anyone here have any expierience with these.
By alexwv1863
I believe the Kawasaki is either an '03 or '04. Green automatic with shifter on the right side. Rear differential was bad, so I replaced it with another. The 4 wheeler rolled in neutral when I parked it in the shop to work on. Took old diff off and replaced it with another one. The diff I put on, turned before I put it on the bike. Once I put it on the bike, the rear end wouldn't move at all. It's like it's stuck in gear. Bike is still in neutral. I've tried rocking the bike while trying to put it in high, won't budge. Can anyone tell me of something to check or try? I haven't opened up the transmission case yet to see what's going on. What should I be looking for?
