By Thumpinhard25
By Kaz
By Dumass
By Trent Finnessey
So I’ve got a 2000 Honda 400ex absolutely love it!! I’ve had it for about a month, I ride with bruteforce 750’s, outlander 850’s and 1000 sxs’s and I was thinking of getting a trx450r carb and a full hmf exhaust. And probably doing the air box mod too, how much power would this give my 400? Just a little different or a big difference? Cuz if it’s not much of a different I’ll just stick with my dg slip on..... thanks!
By fwsamm
