    • By Trent Finnessey
    • By Dumass
    • By Arizona
    • By Ejwill
    • By Ejwill
      I put a new carb on my trx500fe which I have done before on other models, but this foreman was a real pain, takes forever to get to the carb. Anyway I got the new one installed . I also changed the choke cable while I had it this far. When I turned the gas back gas started running into the air filter box. I did have trouble with the choke cable, it didn’t seem long enough to run where the old one did and the elbow that came with the new carb had more of a 90 on the angle. It didn’t feel like it was binding but I don’t know if the valve was seated on the valve seat. The choke pushed in smooth but who knows what happened in side the valve body. I don’t know if this could be the problem or not I hadn’t run the it just turned the gas back on. Appreciate any help, hint, hint Mech and GW or anybody else. Deer season is over in a little over a week. My power chair won’t make it down those muddy roads. Thanks again.
