Correction 80 Badger. Does any one know if this is possible, My in laws have a place in N. AZ and want we want to be able to ride from the house to the trail down the road, and also on the forest roads, Az says we have to have brake light, High and Low beams, Mirror and horn and plate light, Just curious if anyone has done this?
Edited by outodoors
typo
    • By Sportsman500guy
    • By dalton7545
    • By gt_jacket
      Hi,
      I have an 04 bear tracker, with a minor starting quirk. It starts in gear with brake in.  Neutral and Reverse lights work.
      All gears shift fine with no issues,  has anyone seen this before?  Just wondering if it is a bad sensor or something needs adjusting.
