you will need that neutral light on unless it was bypassed ... like dtbprc said, could be bad connection or a broken wire ,,, most times the switch is on the flat of the transmission behind the motor, looks like a sending unit, usually just a one wire deal ...
Thank you. It used to work but quit. I replaced the solenoid, the relay assembly and have ordered a neutral switch. Is it very difficult to install? I've been trying to find out where it is online but not having any luck.
this is what i found on another forum with your 220 ///
There is a switch on the end of the gear change drum that signals when the tranny is in neutral or reverse. It's made of plastic and can sometimes break. More often the contacts are rusted even though it sits in oil.
You have to remove the left engine cover and final drive case to get at the switch. You can often do this by sliding the motor ahead in the frame instead of pulling the motor.
here is a manual for your bike here ... https://www.hightail.com/download/UlRSK2VxZy9tMEp3SGNUQw
I am so aggravated. Finally got the engine down and moved forward. Got to the neutral switch, which was broken, replaced it, got it all put back together and turned on the key.........NOTHING! I just don't know what to do. Any suggestions please.
  • 9 years later...
    • By fwsamm
    • By jwh
    • By JMSwed
      Hi EVERYONE
      New member here
    • By Sportsman500guy
