This is the 4 wheel drive one. Does anyone know why this year has such a special carb? Is there a way to install a different type, like a 2 wd one or a Warrior?:aargh::confused:
Edited by crankin
didnt add the 4 wd
the 97-98 4x4 is special in its own little way , now why that is i have yet to figure out other than they only used it on four wheel drive models, i havent heard of retrofitting to a different style becasue it has the boots on both sides instead of a bolt on but you can find aftermarket replacements on amazon for about 170 i will be getting one next week and will let you know how it works for me
toyotatrukin,
Hopefully you will see this before buying your carb. I found one at zoomzoomparts.com through amazon and it was only around $140. It was delivered in about three days. Perfect fit and this quad never ran so good! I got the quad used and not running so good. I had to use low range to go anywhere. Now I don't even use low range. :yes::biggrin:
    • By Dumass
    • By Trent Finnessey
    • By DPDISXR4Ti
      Thanks...
    • By jhamrick75
