I have a 1996 king quad lt-f4wdx and have oil leaking from the rear axle assy at the seal behind the shaft from the front axle to the rear axle! can this seal be replaced w/o doing major surgery,taking the rear assy completly apart. thanx jim:aargh:
If you are talking about the forward drive shaft seal coming out of the forward crank case, no, can not be replaced easy. Crank case has to be split to get to it.
I have to replace a seal on the rear axle!!!!!!!!!!! The seal is where the propeller shaft attachesto the rear axle!!!!!!!! Via a slip joint connnection with a boot.... So to keep a long story short, is there any chance at all the seal can be replaced w/o dissambling the motor!!!!!!!!!!!!!!!!!!!!!!!!
I don`t understand your terminology. The seals where the rear drive line exit the crank case, you might be able to change it. You would have to dig the seal out around drive line. Might not happen and then you`re stuck. Usually, these are beat out from the inside of the case.
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
    • By Mhatayas
    • By DPDISXR4Ti
      Thanks...
      What oil does everyone like to run in the older quads?
