I have a 2002 Suzuki 300 KingQuad. Starts hard and drags battery down while cranking starter. put in new battery same thing. When it is running and you shut key off startrer makes a clank. Does this sound like a bad starter or bearing in the starter clutch? Any advice welcome!
It pulls hard and it makes the same clank that it makes whrn you turn off the engine. I replaced the starter today and that didn,t help same thing, turns over hard and drags down the battery, When running and you shut it off it still makes a clank sound. It must be in the clutch or bearing.
    • By Mhatayas
    • By beast6228
      However, last night I was looking at the service manual and noticed that it mentioned that this atv has a crankcase breather tube as well. Mine does not have one, so I looked at Partzilla and looked at the parts diagram and sure enough, it's definitely supposed to have one. The problem however is, the service manual does not show how it hooks up and the parts diagram only shows the exploded view of the assembly. I just find that kind of strange, nowhere in the manual does it show how it connects. Does it have it connector, attach to a nipple? It just doesn't say and it bothers me that there is a hole there without anything attached to it.  If anyone has a Bayou 300 or Lakota 300 with an intact breather vent system and could possibly take some clear photos of it or know how it connects I would be very grateful. I have searched high and low and cannot find any information on it.
      Adding to downloads library.
    • By jhamrick75
