The quad starts but wont idle sometimes it idles high then dies.
When riding it will be fine for a while then it will cut out.
It has lots of power, is it time to rebuild the carb or is there other issues?
Check the vac tubes that provide suck to your fuel pump and petcock. If fuel in them, the diaphragms form those components are leaking.
Sent from my Passport using Tapatalk
Definitely seems like you are getting flooding from somewhere. If you dont find in these tubes. Try disconnecting and plugging your fuel line and running it dry from the float bowl to see how it behaves.
Thanks, that is perfect. I bought this quad used and its never run properly. Both those breather lines run up to the shifter and and terminate on a tree. I will need to conect them to the tank and fuel pump and check again
After many hours of frustration, I took the quad into the shop. They are telling me the timing chain may have skipped a tooth and want to tear it down. Does this make sense?
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
    • By Dumass
    • By Trent Finnessey
