Hey guys,
I was just given a yamaha big bear 350 by my neighbor, and I need some guidance. This quad has definitely lived a hard life but I would like to breathe a little life back into it. It starts up and idles great, and shifts into first fine, but its having a really tough time getting into any gear higher than 1st. When I am able to shift it into a higher gear the shifter gets hung up until i push it back down with my foot. My plan as of now is just to change all the fluids, and adjust the clutch according to the manual and see if that helps at all. Any other ideas are very much appreciated.
Also, I cant find a VIN# anywhere on the thing, but I think its a 1997. Its an "SE" 4x4 with the h/l/r selector right next to the engine.
Try this...from neutral pull the shifter up and hold it there and try to move...DON'T DROP IT DOWN WHILE REVVED...if the bike still feels like it's in neutral there and drives good in first your clutch is adjusted fine where it is and can be tedious getting it back.....after that u could try changing your oil if it looks that bad but I'd get a new clutch cover gasket and take the cover off its the big one on right hand side there's about 12 8 mm bolts. An oIL line and your reverse switch......when pulling the cover off there's a few pieces that can fall out a plate with 3 ball bearings in it (fixed) they can't fall out.. a spring and a couple pie shaped gears....all part of your secondary clutch....n just go from there make sure shaft from shifter to cam isn't bent n binding...something in there is probably binding unless it's right inside the crank case.....if it is I have a crank case/transmission I could sell.....I have 1 with the high/lo version off a 99 Kodiak. ..in 2000 they changed the name of the Kodiak to big bear and gave the Kodiak a CVT. ....and I have one off a 350 wolverine without the hi/lo option ..
Thanks for the response, gangle.
I tried what you said, but when I shift into first and keep the lever up it pulls forward like its in gear. However, I took it for a quick spin and it seemed to shift fine through all the gears. I wasnt able to ride it very long due to some carb issues, but it seemed ok. I changed the oil with Rotella T6 5w40 and also changed the fluid in both diffs, after I get my carb kit I should be able to take it out for a ride and post an update.
How it's running is not ok ....your clutch is out of adjustment. Way out. My guess is the clutch started slipping and the past guy backed the adj. Screw all the way out thinking it would be tighter but it's not...your secondary clutch (clutch pack) is not doing its job at all..it's job is to take the quad out of gear when u push up or down on shift lever just like a standard clutch...that's why your having trouble shifting....what u have to do is turn adj. Screw in 1/8th of a turn. Pull lever up/down. Hold and hit gas. If the quad is trying to move repeat until it doesn't. And once u get that set up so it's not trying to move go for a rip and make sure it doesn't slip....it shouldn't. .. if it does just back it out 1/8th of a turn .....the way it is now is hard on transmission gears...also if clutch is slipping...I won't get tout into it but make sure your running a jaso-MA certified oil...and definitely no synthetics that's aren't jaso-MA approved..they will swell your clutche's cause premature wear and slip
Nope if clutch was toast it'd be slipping there's something wrong inside that clutch cover ..something with the whole secondary shift mechanism. U try turning it both ways? If I remember right they are backwards threads. It might not be worth the hassle with a free bike...it's an easy fix ...without a picture or diagram it's hard to describe how it works n I can't find one...it shouldn't hurt anything if u completely let gas go when shifting...the primary (centrifugal) clutch actually has a one way bearing so if the wheels are spilling the clutch bell (outer part) faster then the cent. clutch is spinning there is no pressure on any gears when shifting.. it's a personal thing is u wanna year it apart n possibly spend a few bucKS giver if not dont
    • By Thumpinhard25
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
    • By Frank Angerano
