Hi there,
My 1989 suzuki ltf-250 quadrunner is having spark problems it seems to only fire 1 bright spark when you first hit the starter button then loose spark most of the time. Other times it will spark nice and bright and run good. I have a new battery in it and it shows 11.5v while cranking and also has a new coil. any ideas on what could be causing this problem.
To start check for loose connections and wire damage in the charging and ignition system. Sounds like an intermittent problem. When it is running, does your battery have higher voltage? If so, indicates the charging system is working.
checked over all the wiring tonight and it all seems fine charging system is working fine when it wants to run. tested the power out of the ignition switch and it is 11.3v when engine is cranking wobbled all the wiring around to see if that made a differents and it didnt then after 10 min of tapping on all of the electric parts it decides to spark on every cycle of the engine. any ideas on what electrical component could cause this.
Very cool. The CDI is solid state so once it dies its dead. Probably something in the unit came loose. The Clymer manual has good testing procedures for it. That yours is intermittent is a bit odd. Id still double check your connections.
The pic below is a 93KQ Im tearing down. The connector shroud to the left is crammed full of mud. I just wonder if yours is clean and secure.
Do you have Ebay in the land of Auz? Usually a good source of used parts for me.
Edited by Tim-ANC
    • By Tim Keiper
    • By Frank Angerano
    • By Mhatayas
