I had some leaky seals and a bad running Polaris 250 2x4 mod W937527.Compression was 90 lbs.Just had the cylinder to a shop for measuring.Standard 72mm is 2.835 inches this cylinder is round and measures 2.839 and a bit wider at the bottom.The ring gap with the used rings is .25.
Here is my question>The piston has the ring stops that pin,Can I use the standard piston with a ring set .10 over?
The manual says ring gap seated in the cylinder should be .0009 to .0018.
I am disabled and it will only run me 800 ft to a mailbox once a day and maybe a little use around the yard,so a bore,and new parts are out fixed income cant afford that.
Can I go .010 over on the rings with the standard piston?
Thanks for any advice
No. Cant do that.
90 comp isnt too bad. measure the piston to cylinder difference. Max is .007.
Maybe just stock rings will do it.
You are already buying rings and gaskets. I see the piston is $104. Might have to get a new piston .025 over and have the cylinder bored.
powersportswarehouse.com for parts
I have the specs for the motor.I never start any engine without them the piston skirt clearence with the original piston is .0011 to .0021 according to the book.I have .0042.No place will bore .25MM over.They all start at .50MM or .020.I cant afford that.Creating to much compression has at times on old used engines created lower case problems. I have one engine here bored,crosshatched, ringed and piston with new pin bearing.ran as breakin 1 hour later the rod broke. rod had 3300 miles of stress on it. Can you please explain why a .25MM over ring wont work??
Thanks for the reply out of 3 posts on 3 different sites your the only one who tried to help!! Thanks
PS I am a outboard mechanic,I have plenty experience with 2 strokes.These pistons with that ring stop pin has me baffled.I have and can yet put a file to the ring if the pin area needs to be made to the same size as a standard ring.I just want to be closer to specs when I put it back together.
Edited by dew2
Ok, Im reading that as you have 4 thousandths clearance. That is within spec. Id get stock rings.
To explain about the .25mm over ring thing:: you would need alot more clearance to get them to fit.
The pin in the piston is so the ring ends dont ride over the ports and cause damage. 4 strokes dont have the pins cuz the rings are supposed to spin.
The ppl you asked about boring is goofy to me. They could bore .25mm with their precision hone.
Ill see if I can send a guy over to help.
Here is a reply I got from a polaris mechanic:::
"Nope,wont work,or at least not for long... The cylinder is already worn down .004 over standard bore and I assume the stock piston is in about the same shape or worse. When the piston/cyl clearance gets around .005 they start rattling,then later on people wonder why the piston skirts broke! Can't do like they did on cars years and years ago and just use oversize rings. Plus it'd have to be honed down to even get the .010 oversize ring end gaps to work which would make it even worse on the stock piston to cylinder clearance. Lot of shaking and rattling would be going on and just plain wrong. Says he has to only go 800 feet to check the mail,but think he'd be walking about 600 feet of that when the engine goes south on him. He'd be better of just trying std rings and seeing how long it'd last. But sooner or later he's gotta bite the bullet and do it right,new oversize piston and rings,cylinder bore then he can go check the mail and maybe even go a little further... "
I understand money is tight but to do it right is about $175. more (115 for the piston/60 for the bore) than youll have in it anyways.
Well hey I sure do appreciate the feedback.This is the only answer I received from 3 sites.It does sound like excellant info.So thank you I have the cylinder cleaned up crosshatched and 2 sets of rings on the way.
    • By Mhatayas
    • By oxidized_black
    • By jhamrick75
    • By Sportsman500guy
    • By GatorHunter
      Thank you, and enjoy
      GH
      1985 Scrambler
      1985 Trail Boss
      1986 Scrambler
      1986 Trail Boss
      1987 Trail Boss
      1987 Trail Boss 4X4
      1987 Cyclone
      1988 Trail Boss 2X4
      1988 Trail Boss 4X4
      1988 Trail Boss 250 R/ES
      1989 Trail Boss
      1989 Trail Boss 2X4
      1989 Trail Boss 4X4
      1989 Big Boss 4X6
      1990 Trail Blazer
      1990 Trail Boss 250
      1990 Trail Boss 2X4
      1990 Trail Boss 2X4 350L
      1990 Trail Boss 4X4
      1990 Trail Boss 4X4 350L
      1990 Big Boss 4X6
      1991 Trail Blazer
      1991 Trail Boss 250
      1991 Trail Boss 2X4
      1991 Trail Boss 2X4 350L
      1991 Trail Boss 4X4
      1991 Trail Boss 4X4 350L
      1991 Big Boss 4X6
      1991 Big Boss 6X6
      1992 Trail Blazer
      1992 Trail Boss 250
      1992 Trail Boss 2X4
      1992 Trail Boss 2X4 350L
      1992 Trail Boss 4X4
      1992 Trail Boss 4X4 350L
      1992 Big Boss 4X6
      1992 Big Boss 6X6
      1993 250 2X4
      1993 350 2X4
      1993 250 4X4
      1993 350 4X4
      1993 250 6X6
      1993 350 6X6
      1993 Trail Boss
      1993 Trail Blazer
      1993 Sportsman
      1994 300 2X4
      1994 400 2X4
      1994 300 4X4
      1994 400 4X4
      1994 300 6X6
      1994 400 6X6
      1994 Trail Boss 2W
      1994 Trail Blazer 2W
      1994 Sportsman 4X4
      1994 Sport
      1995 300 2X4
      1995 400 2X4
      1995 300 4X4
      1995 400 6X6
      1995 Trail Boss
      1995 Trail Blazer
      1995 Sportsman 4X4
      1995 Sport
      1995 Xplorer 4X4
      1995 Scrambler
      1995 Magnum 2x4
      1995 Madnum 4X4
      1996 Trail Blazer
      1996 Trail Boss
      1996 Xplorer 300
      1996 Xpress 300
      1996 Xplorer 400
      1996 Xpress 400
      1996 Sport
      1996 Scrambler 4X4
      1996 Sportsman 4X4
      1996 Sportsman 500
      1996 400 6X6
      1996 Magnum 2X4
      1996 Magnum 4X4
      1996 Magnum 6X6
      1997 Trail Blazer
      1997 Trail Boss
      1997 Xplorer 300
      1997 Xpress 300
      1997 Xplorer 400
      1997 Xpress 400
      1997 Xplorer 500
      1997 Sport 400
      1997 Scrambler 4X4
      1997 Scrambler 500
      1997 Sportsman 4X4
      1997 Sportsman 500
      1997 400 6X6
      1997 Magnum 2X4
      1997 Magnum 4X4
      1997 Magnum 6X6
      1998 Trail Blazer
      1998 Trail Boss
      1998 Xplorer 300
      1998 Xpress 300
      1998 Sport 400
      1998 Scrambler 400
      1998 Scrambler 500
      1998 Xplorer 400
      1998 Magnum 2X4
      1998 Magnum 4X4
      1998 Sportsman 500
      1998 Big Boss 500 6X6
      1996 Sportsman 400
      1996 Sportsman 500
      1996 Xplorer 500 4X4
      1997 Sportsman 400
      1997 Sportsman 500
      1997 Xplorer 500 4X4
      1998 Sportsman 400
      1998 Sportsman 500
      1998 Xplorer 500 4X4
      1999 Sportsman 400
      1999 Sportsman 500
      1999 Xplorer 500 4X4
      2000 Sportsman 400
      2000 Sportsman 500
      2000 Xplorer 500 4X4
      2001 Sportsman 400
      2001 Sportsman 500
      2001 Xplorer 500 4X4
      2002 Sportsman 400
      2002 Sportsman 500
      2002 Xplorer 500 4X4
      2003 Sportsman 400
      2003 Sportsman 500
      2003 Xplorer 500 4X4
      A01CH50AD
      A01CH50AA
      A01CH50AB
      A01CH50AE
      A01CH50AK
      A01CH50AF
      A01CH50AJ
      A01CH50EB
      A02CL50AA
      A02CL50DA
      A02CH50AA
      A02CH50AB
      A02CH50AE
      A02CH50AK
      A02CH50AC
      A02CH50AD
      A02CH50AJ
      A02CH50AL
      A02CH50AM
      A02CH50AN
      A02CH50FA
      A02CH50AAEB
      A02CH68AA
      A02CH68AB
      A02CH68AC
      A02CH68CA
      A02CH68CB
      A03CL50AA
      A03CH42AA
      A03CH42AB
      A03CH42AC
      A03CH50AA
      A03CH50AA
      A03CH50AA
      A03CH50AA
      A03CH50AA
      A03CH50AA
      A03GJ50AA
      A03GJ50AB
      A04CL50AA
      A04CH42AA
      A04CH42AE
      A04CH42AG
      A04CH42AQ
      A04CH42AT
      A04CH42AV
      A04CH42AS
      A04CH42AR
      A04CH50AA
      A04CH50AC
      A04CH50AE
      A04CH50AG
      A04CH50AO
      A04CH50AQ
      A04CH50AR
      A04CH50AS
      A04CH50AT
      A04CH50AV
      A04CH50AW
      A04CH59AF
      A04CH59AH
      A04CH59AJ
      A04CH59AT
      A04CH59AV
      A04CH59AK
      A04CH59AL
      A04CH59AN
      A04CH59AW
      A04CH68AC
      A04CH68AF
      A04CH68AH
      A04CH68AJ
      A04CH68AT
      A04CH68AV
      A04CH68AK
      A04CH68AL
      A04CH68AN
      A04CH68AO
      A04CH68MB
      2004 Ranger 2X4 Parts Manual
      A04RB42AA
      2004 Ranger 4X4 Parts Manual
      A04RD50AA
      2004 Ranger 6X6 Parts Manual
      A04RF50AA
      A05CL50AA
      A05MH42AB
      A05MH42AG
      A05MH42AH
      A05MH50AB
      A05MH50AC
      A05MH50AG
      A05MH50AH
      A05MH50FB
      A05MH59AK
      A05MH59AN
      A05MH68AK
      A05MH68AN
      A05MH68AC
      A05MH68AS
      A05MH68AU
      A05MH68AW
      A05MH76AC
      A05MH76AU
      A05MH76AW
      A05MH68AP
      A07MH68MA
      R07RF68AD
      R07RF68AF
      R08RF68AD
      R08RF68AF
      2009 Outlaw 90 service manual
      Other Stuff
      Download Manuals HERE
      Some ATV manuals available in the downloads section at https://www.quadcrazy.com/files/
      Find them on on:
