I am having problems with my 2002 suzuki vinson 500 the battery will not hold charge i can charge it and start it and the voltage starts droping the display flickers and when i rev it it backfires can someone give me some ideas what might be wrong with it
Edited by nickvinson9768
I have a 2002 vinson and had kinda the same problem once .I took and unplug and cleaned all my electrical plugs .They had mud caked in them from the previous owner it has ran fine since. Hope this helps.
    • By Trent Finnessey
    • By Tinkeringreg
    • By Mhatayas
    • By kaidella
    • By oxidized_black
      Engine
      Chassis
      Size
      Basics
      Features
