I am selling my Honda trx 70.
It is all original everything, I have owned it since 1988 and it runs excellent and everything works as it should. Trans is good, brakes are good, steering, levers & cables, tires....everything perfect.
The only issue with it is that it needs a seat cover since the original one is cracked in a couple places
Plastic is scratched up a little but has zero cracks. The decals are all there but some are a little rough. ( It is 28 years old)
It's stored indoors and has been for about 20 years.
Perfect for small kids or bigger kids. I am 290 lbs and it carries me anywhere and everywhere. surprising power for a 70cc.
Starts on the first or second pull (If I remember to turn on the gas) :aargh:
Asking $750 or make me an offer - can email pics if interested. (not sure how to put them on here.
I am in central Arizona -Payson, Az. email me at mwood85541@hotmail
Edited by mwood
added email address
No comments or anything?
Am I asking too much? What do you guys think it's worth?
I was going by what someone told me it's worth, I had no idea. I tried looking to see what they were going for but couldn't find any for sale.
If I am way off any input would be appreciated....
    • By Trent Finnessey
    • By Dumass
    • By Arizona
    • By oxidized_black
      Engine
      Chassis
      Size
      Basics
      Features
