I have a 2003 kodiak, 450, that the tail, light is being turned on by front brake control handlebar lever which I dont think should even happen . I have disconnected the brake switch by removing the spring. You can barely touch the lever and the tail light comes on the problem is after parking there is enough contact that the light dont burn but it will run the battery down in a period of 24 hours. Its a good machine with right at 5000 miles and 1500 hours but I am at the end of my rope with it
    • By Trent Finnessey
    • By DPDISXR4Ti
      Thanks...
    • By TravisM
      2001 bayou 220 KLF220A
      I'm at a loss here. Thanks.
    • By mans
      Were is the neutral safety switch on 03' Kodiak 400 4x4 . How xan i check it to see if it's good for a no neutral light no power to machine. Ty
    • By leecon
