I know that for autos,trucks etc there are alot of parts that can be interchanged with in the same mfg such as gm,chevy. Is this also true for suzuki quad runner and other models? if this is true is there a book and or link that can make this possible? jim
i think the easiest way to do this is, get an online seller (bikebandit.com, rockymountainatv.com) that lists the parts you need and has the blow outs showing everything, and go to each item and see if its the same part number, i havent seen a book or listing that lists interchanges, but they might be out there ... i usually do this with two IE pages and go back and forth to see if items match ...
it depends on the parts. OB is right though, you can compare via online parts suppliers - OEMs have a part number interchange through their inhouse systems. Beware, sometimes different part numbers are for different paint colors - CB1000 used the same head as a CB900 but it was painted silver instead of black so according to OEM they were not interchangeable.
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
    • By Mhatayas
    • By Ethan7387
    • By mmikesell
    • By opnea
      Recently picked up a 1991 Lt230e for repair. Compression is a little low Id say, around 80psi, I also have spark but the spark is odd . When cranking the spark is a constant arc. I’ve got it to sputter but never fully turn on. I believe the spark is my issue, being constant and not detonating at the right time. I’m not sure whether this issue is an electrical fault like some missing ground, a faulty cdi, or a timing issue. Any ideas where I should start?
