Hey guys and gals I have a 2000 wolverine that it seems like the starter is engaging but the engine isn't turning over. Any help.would be appreciated. Thanks in advance, Barry
the starter clutch sprag assembly is shot - it's a one-way bearing assembly on the back of the flywheel, 3 or 4 rollers are spring loaded to let the gear the starter engages freewheel in one direction but lock up the other way. You'll likely need a new flywheel and gear assembly - I'd look for a used one cause new isn't going to be cheap.
    • By Trent Finnessey
    • By Randomnumber73
    • By Ethan7387
