I have a 2010 kingquad lta400 I was wondering if there is transmission fluid that I should replace. it was a long winter of plowing and I am changing all fluids. if there is transmission fluid what kind should I buy?
your atv motor oil does the transmission ... make sure you replace it with ATV oil because it has additives for a wet clutch transmission ...
ok thank you!
So mine is a 4stroke 2 wd do i need atv oil
you should always use atv oil, it is different than the car/truck oil ... car/truck oil will eventually wear the clutch and transmission out. seems all the atv manufacturers have their own brand of oil they recommend, but any good brand ATV oil will be good ...
any idea where I can find what weight oil I need to use? I cant find the information anywhere for some reason. I have a 2010 kingquad LTA400AS 4X4
    • By qcm413
      Hi,
      thank in advance
      Covers the following models:
      1985   Scrambler Trail Boss
      1986   Scrambler
      1986   Trail Boss
      1986   Scrambler
      1986   Trail Boss
      1987   Trail Boss
      1987   Cyclone
      1987   Trail Boss 4x4
      1987   Trail Boss 4x4
      1987   Trail Boss 4x4
      1988   Trail Boss 2x4
      1988   Trail Boss 4x4
      1988   Trail Boss 250 RIES
      1989   Trail Boss
      1989   Trail Boss 2x4
      1989   Trail Boss 4x4
      1989   Big Boss 4x6
      1989   Big Boss 4x6
      1990   Trail Blazer
      1990   Trail Boss 250
      1990   Trail Boss 2x4
      1990   Trail Boss 2x4 350L
      1990   Trail Boss 4x4
      1990   Trail Boss 4x4 350L
      1990   Big Boss 4x6
      1991   Trail Blazer
      1991   Trail Boss 250
      1991   Trail Boss 2x4
      1991   Trail Boss 2x4 350L
      1991   Trail Boss 4x4
      1991   Trail Boss 4x4 350L
      1991   Big Boss 4x6
      1991   Big Boss 6x6
      1992   Trail Blazer
      1992   Trail Boss 250
      1992   Trail Boss 2x4
      1992   Trail Boss 2x4 350L
      1992   Trail Boss 4x4
      1992   Trail Boss 4x4 350L
      1992   Big Boss 4x6
      1992   Big Boss 6x6
      1993   2502x4
      1993   3502x4
      1993   2504x4
      1993   3504x4
      1993   Sportsman
      1993   2506x6
      1993   3506x6
      1993   Trail Boss
      1993   Trail Blazer
      1994   3002x4
      1994   4002x4
      1994   3004x4
      1994   4004x4
      1994   3006x6
      1994   4006x6
      1994   Trail Boss 2W
      1994   Trail Blazer 2W
      1994   Sportsman 4x4
      1994   Sport
      1995   3002x4
      1995   4002x4
      1995   3004x4
      1995   Xplorer4x4
      1995   4006x6
      1995   Trail Boss
      1995   Trail Blazer
      1995   Sportsman 4x4
      1995   Scrambler
      1995   Magnum 2x4
      1995   Magnum 4x4
      1995   Sport
    • By p5200
    • By DGBear
      My front brakes started dragging and the lever travel was minimal. I bled them and topped off the fluid reservoir and they worked great for a while and now the problem has returned. I'm thinking that a piston may be sticking. Any thoughts on this problem?
