By p5200
By mga
I have a Yamaha Big Bear 400 4x4 2000. I've posted on here about the frame being bent. Does anyone know what year frames are interchangeable? Also, would the frame from a 350 be the same as a 400? Would it matter if it was a 4x4 or 2x4?
thanks for any help with this
By onequad
i got a 93 400 Kodiak the frame on one side is rusted out. is this a comin thing? was wondering if it worth the tumble to put in a used one. I'm worried most of the bolts will brake. it don't look the rusted over all. just the part were the frame boke in half. do all kodiaks have the same frame
By McG75
Sorry I suck at these forums so if you see this submitted under update status, my bad. Anyhow this is a new shock for a 96 Yamaha Kodiak 400 4x4 it fits my 96 Yamaha Timberwolf 250 4x4 perfectly. Little narrower are the bottom than the original but everything else is perfect. I extended it to almost a half in from full extension because I’m pushing 350 pounds. It rides and hold me well. So if any of y'allRace driven shock. have been looking for one and didn’t want to do the research here it is.
By Johnnyhorsepower
I finally found an awsome app for your phone that shows you on a map all the trails near your location. You can read or add reviews, look at picts...etc
Its called: atv escape
John
