Looking to see if y'all can help me out. What motors fit in the 04 Warrior frame? What about an 03 warrior frame? Any other years interchangeable?
Thanks!
    • By carkivey3
    • By mmikesell
    • By EasyE
    • By opnea
      Recently picked up a 1991 Lt230e for repair. Compression is a little low Id say, around 80psi, I also have spark but the spark is odd . When cranking the spark is a constant arc. I’ve got it to sputter but never fully turn on. I believe the spark is my issue, being constant and not detonating at the right time. I’m not sure whether this issue is an electrical fault like some missing ground, a faulty cdi, or a timing issue. Any ideas where I should start?
