By ATVNetwork
This past weekend the 2025 ATV Motocross National Championship Series (ATVMX), an AMA National Championship, held its third round of AMA Pro ATV racing, and its first amateur round of racing at Echeconnee MX in Lizella, Georgia. View the full article
By Sportsman500guy
By Gwbarm
IMG_4910.mov There is some slack in there but most is taken up by the gear cover,if anyone with history with these machines has had the same problem, let me know your findings. Where i am now im looking for finding replacement honda gears on Ebay and try those. I suspect the original was replaced with aftermarket gears years ago and they just worse quality as the years go by.
By alexwv1863
I believe the Kawasaki is either an '03 or '04. Green automatic with shifter on the right side. Rear differential was bad, so I replaced it with another. The 4 wheeler rolled in neutral when I parked it in the shop to work on. Took old diff off and replaced it with another one. The diff I put on, turned before I put it on the bike. Once I put it on the bike, the rear end wouldn't move at all. It's like it's stuck in gear. Bike is still in neutral. I've tried rocking the bike while trying to put it in high, won't budge. Can anyone tell me of something to check or try? I haven't opened up the transmission case yet to see what's going on. What should I be looking for?
By DGBear
This thing is stuck in reverse! 2021 Axis with less than 15 hours on it. I cranked it, let it idle for a few minutes and when I put it in reverse the engine died and it won't come out of reverse gear. Any help is appreciated.
