Help my Kawasaki bayou 300 1986 model won't start, replaced coil, and cdi valve. does not spark with new spark plug....what next????? It is one owner and we have maintained nor well so I known it has not been mistreated and should be able to repair, I like it better than the new ones for working on the farm, easier to handle for me!!! thanks for any help,
if you can take the kill switch and ignition switch apart, inspect and clean that first, make sure the neutral safety switch is working properly, light in speedometer pod coming on? you can take a volt meter to the wires coming out of the crankcase for the stator. not sure which side on a kawi, left side sitting on bike? i think maybe a bike this age, the stator may need replacing, but check everything else out first ....
Edited by oxidized_black
    • By Tinkeringreg
    • By Kawasakibayounospark
