Have been using it to plow my driveway, worked fine until about a week ago. Suddenly the front wheels are the only one engaging and the rear wheels are not. Shifts and goes forward and reverse just fine but with front wheels only.
Any Ideas
This may help some one else, I did as oxidized_black suggested and found that the final drive was making a bunch of grumbling noises, dis assembled the final drive and found that the pinion gear and the solid rear axle were not engaging due to the fact that the splines on both had rusted and unable to work with each other. This was due to the fact that water had entered into the housing and over time had caused this damage. In the process of researching parts and options I found out the it was a 96 and not a 98. The simple act of changing the final drive oil as suggested in the maintenance schedule suggested by Honda would have prevented this costly repair.
    • By DaleJAM
    • By Winnem
      Hello.
      I've bought myself a Iron Baltic electric hydraulic plow lifter for my TGB, with a matching mounting kit. It was supposed to fit directly on my ATV. But I'm really not happy with the result. Had to cut off some of the cover under the atv, and still the angle didn't seem to be right in order to fasten the adapter on top. Also it touches the bumper and makes ugly marks.
      Is there anyone here with experience, or know a good solution on this?
    • By Joeboe
      This snowplow is a winner!
