Changed oil, removed and cleaned float, needle and seat, and carb, changed oil again, still, several gallons of gas seep I to crank case, any ideas please? Not very good at setting the float so I dread rebuilding the carb.
if you hold the carb upside down and level with the bowl off, measure the distance from the mating surface of the bowl to the top of the float, i think if you are at a half inch or less you should be good. there is a metal tab where the needle slides onto to the float to adjust if need be ...
    • By Travis_Smith
    • By Mhatayas
    • By Dumass
    • By Trent Finnessey
    • By Arizona
