(This Ad is from QUADCRAZY Classifeds, click "More" to find out how to contact the person who placed this ad.)
2012 CAN AM Outlander 1000R XT yellow with power steering, 93 miles. Full auto with high/low reverse and electric start, independent suspension front and rear, 2 and 4 wheel drive on demand, has hand guards, warn winch, mud guards, heavy duty plow. Very c...
More...
    • By Tinkeringreg
    • By kaidella
    • By jwh
    • By Mmessy83
      I recently purchased a complete lt230s for$50. It was missing the kick starter gears which I got off eBay for $18. I’m trying to install the gears which after reading different threads about having it timed. I have it all timed but now it acts like engine is seized up but I know it’s not. What could be going on??? Any insight would greatly be appreciated.
    • By gt_jacket
      Hi,
      I have an 04 bear tracker, with a minor starting quirk. It starts in gear with brake in.  Neutral and Reverse lights work.
      All gears shift fine with no issues,  has anyone seen this before?  Just wondering if it is a bad sensor or something needs adjusting.
