so I went out and bought a real clean 89 350 warrior it started fine and was a little cold blooded but once it was warm ran like a beast any way I went over a snow bank and I caught a little bit of air and as soon as the tires hit it just died!!! I didn't hit vary hard this was a small snow bank an I ran over it fine a few times before but not that fast can you guys give me some advice before I tear it apart tomorrow? thanks guys
its getting spark and didn't get wet im gunna change the plug but my hunch is that aint it and ive checkd reverse to make sure its not ingageing in any way and fiddled with every conection I could see with the plastics on headlites werk and all will crank over all day long but no start and also made sure its getn gas its still goin threw the line
Edited by davidiz420
I did locat the wire I think your referin to and cant find where it goes dosnt seem to be any other conector or place forit could it of broke off some how? duz it like clip on to the tranny from the bottom??? and im pretty sure itdont got a light
ok I am for sure getin spark when I try push starting it I get the same results im gunna try poring some gas in the plug and see if it will fire then
update I changed the spark plug went threw and plugd and unpluggd every conection its getting fuel and spark I sprayed the air filter with quik start and still nothing
could this have something to do with my pool rope breaking the black part came off while running and sucked the rope back in and it was spinning I took it off and took the rope out and reasembeld and was running fine till I hit a hump then it just died it will crank but could the fly wheele or whatevers next to the pull starter be the culprit???
also could it be the clutch casing it to not fire ?????
Re: 1989 Yamaha Warrior 350 - Wont Start
also could it be the clutch causing it to not fire ?????
That is why I hate messing with electrical issues. You could chase it from one end of the quad to the other and back again. I wish you luck and keep posting the results. I am waiting for my tax return and sending my to my mechanic. This is one issue I don't mind paying him to figure out, besides it is too damn cold in my garage to do any work now.
yes but if its getting spark and cranking over perfectly than I don't think it would be electrical I think it has something to do with the pull start any body else have problems after they've done fuckd up there pull start?????
and also if the clutch is out or not properly working could that be the cause when I pull clutch and try to start it still trys to go forward a little and its adjusted all the way out already
:aargh::aargh::aargh:
do a good read so you know what youre up against ... make a plan of attack ... take your time ...
well the cam exploded it ruind the sprocket on the upper part of the timing chain and also did some damage to the chain guide should I rebuild and with what stage 2s or????
Damn, that is crazy. It doesn't sound like you were really beating on it. What made it go apocalyptic on you?
faulty repairs whoever rebuilt it last used a longer bolt and washers to hold the cam and timing chain when it loosened up it just started eating away the timing sprocket chain guide and cam is all destroyed... I HATE CRAIGSLIST!!!
https://scontent-a-ord.xx.fbcdn.net/hphotos-frc1/t1/1800193_592714300807123_208809996_n.jpg
https://www.facebook.com/photo.php?fbid=592714300807123&set=pcb.592714410807112&type=1
https://scontent-a-ord.xx.fbcdn.net/hphotos-prn2/t1/1546247_592714054140481_1346128971_n.jpg
https://www.facebook.com/photo.php?fbid=592714054140481&set=pcb.592714410807112&type=1
    • By Gunny
      Hope you enjoy the video ....
