first off i have 2 parts bikes a 97 kodiak 400 and 97 wolverine 350 and a running 02 big bear 400......i just replaced my piston, cyl. and head with the one off the kodiak 400 but ripped my carb joint(from carb to head). my question is can i use the wolverine 34mm? carb on my big bear that now has a 33mm. they are 2 totally different carbs...wolverine stock has main 145 and big bear has 110 main forget what the pilots are....im thinking it should work but wanted to be sure. the reason i wanted to use that carb is it has a different style joint and i have the joint and its in good condition. any help would be aprreciated thnx
i read on one of the forums someone did this before, could of been a warrior carb, but everything joined up nice and the only thing they had to do was play around with the jetting ... hope this helps ...
Edited by oxidized_black
well thats why i want to use it the wolverine uses a different joint has a flange type on one end and hose clamp on the other instead of two flanges i wanna switch carbs so instead of buying joint only paid 500 for kodiak and big bear dont wanna pay any more lol
this thread can be deleted i figured it out took half the big bear joint (head side) honed it out to fit on carb side, used the joint off the wolverine and attached it to joint on carb the result was the carb an inch higher and in the center, still works with stock air box with snorkel off, then had to raise the gas tank half an inch using the rubber gas tank mounts off the kodiaks placed under the mounts already on the big bear. all i can say is wow, i guess this quads been slowly going downhill since before i bought it, huge power difference, exhaust sounds crisper, revs quiker, harder in 5th then it did in 3rd before, this things torque and all using used parts
    • By Atomusthenes
    • By Tim Keiper
    • By Thumpinhard25
    • By Frank Angerano
