2007 Kubota RTV 1100 4X4 Diesel only 66 hrs (san antonio)
By jwh
I am new to this site. Now down to business, I have been given a Kawasaki 220, tires are trashed and it has been setting for a long time. Do I need a battery in it to find neutral? I know there is a neutral switch and if I shift down(7 times????) then up one using the neutral switch I should be in Neutral. As you see I am in a learning curve here ......coments welcome.
By Ejwill
By Eisaks777
hello, i have bpr bombaradier rally 200 2007 which has a lot of gasoline in the oil sump, it is 4 stroke. Has anybody had problem like this and which can be the cause and how to fix it. i rode it today at -2 degrees celcius if it helps.
