Hello All,
- I have a 1996 Sportsman 400 4x4 2 stroke, and the fuel petcock leaks like crazy. It leaks around the red barrel that rotates to the 3 positions, on off and reserve. Can it be repaired or is replacement the only cure?
Thanks in Advance.
I tried to take it apart to look at but it does not come apart. At least it was not obvious. I was sure it would break if I tried to pry the handle off. Anyway, I have a whole new peacock coming.
UPDATE - I installed the new unit and it works great, as expected and it takes much more effort to rotate it. Not allot but much more then the old one. I also found out these units are easy to break trying to disassemble them! Glad I ordered the new one.
Thanks for the input!
BradCad
    • By Travis_Smith
    • By KSIM
      View File CFMOTO C-Force 400 service manual
      C-Force 400
