Hey I recently picked up a 1991 suzuki ltf 250 quadrunner when I went to look at it it started right up just needed a little carb work. After the carb work was done 2 pulls later it started right up but once I turned it off and tried to start it again it wouldn't start and when I cheched the plug there was no spark. I've looked around the internet to see if there's any other simalar situations with other peoples quads, but there was nothing the exact same situation, after doing research I've came up with a conclusion that its the neutral safety switch but I haven't been able to locate it on my quad. If anyone has any advice or tips it would be or if you've had the same problem let me know how you sloved it! Any info will be greatly appreaciated, thanks.
    • By Tinkeringreg
    • By Mhatayas
    • By Dumass
    • By Trent Finnessey
