:mad:Have an issue with a dead battery and when replaced the fan immediately came on without the key even being in the machine. Dash or instrument panel flashes HOT. Any ideas what could be wrong. Understand that there was a recall on this model? How many times can the computer or what ever they call it needs to replaced. also heard it was a fire hazard.
thanks
    • By Dumass
    • By fwsamm
    • By Dsluder
    • By waybel
      Picked up this old 2000 polaris sportsman 500 and the speedometer is dead .Tried the bypass to get the awd drive to work but no luck.I grounded the 2 brown wires going to the hubs .Didn't work.The AWD light does not come on and there is no power on the grey wires going to the hubs .I even tried connecting the 2 brown wires at the speedometer plug in .There is 12 volts on the red with white stripe connected to brown at the speedometer plug in .Does the speedometer need to be plugged back in for this to work.Could it be the switch or a burned AWD bulb ?
    • By disturbedmike244
      I have a 99 kodiak 400 4x4 that blows a fuse under the back left fender as soon as you attempt to put a new one in even with the key turned off. I'm having a hard time finding any wiring diagrams that show what this is for. And I'm trying not to have to tear into the wire harness. Any help would be appreciated.
