By Shadow soul60
So I want to put LED headlights in my 99 Bayou 220. The stock headlights have some issue in the connector and they only work some of the time, so I want to replace them with LED light bars. I want to run them off the high beam switch. Which wire would this be?
By TravisM
2001 bayou 220 KLF220A
I'm at a loss here. Thanks.
By P_syko
Are the cheap tires from Amazon any good? I know nothing last forever, but don’t want them to dry rot in a year.
By DaleJAM
