My wife has a well used 325 Trail Boss and recently she noticed there is a distinct rhythmic clicking or popping noise that sounds like its coming from the chain/ sprocket area. Increases with speed and happens in fwd or reverse.
I jacked up the rear of the quad and rotated the tires and there is no sound when the drivetrain is unloaded. Any suggestions on what this could be or how to troubleshoot? Im new to 4-wheelers, so this might be something pretty simple but I just dont have much experience working with them.
Would appreciate any help or suggestions
My first quess would be bearings ! Is the rear a straight axle ? If it is jack it up and see if ur tires move up &down or Side to side !
Yeah, its a chain drive sold axle. Ill jack it up and see if I there is any movement. The sprockets and chain dont look worn but looks like its adjusted pretty tight. Could it somehow be binding and popping free as it rotates?
    • By TimothyLindblom
      Hey all, I just picked up this Massimo UTV for $500. Got it home and replaced the starter solenoid which successfully got power to the starter. Starter spun but engine didn't turn over although the engine is not locked up. I thought it was a bad starter. Got a new starter put on today and it does the same thing. Pulled the clutch cover and saw the engine is trying to turn over but something is slipping and not letting it turn over. I figured it must be the gear on the engine that the starter turns. Where can I get that and can it be replaced without pulling the motor? And am I correct that that's the issue?
      Thanks!
      Short video attached below
    • By Mhatayas
