New memeber here..like most came looking for some help..other forums i have tried have not gotten any responses..so here goes
2001 wolverine..when problems started i went for a ride and 10 minutes into it, bike shut off..i could use push button and fire it back up..few mintues later shut off again this time i had to pull start it..drove it home and parked it..from then on i could not use push button or pull start.when i pushed start button no clicks or anyting, neutral light and oil light came on but that's it..so i inspected kill switch..it was bad..so i rewired to bypass kill switch (i think i got it right)..after this when i pushed start button i got a single click at the start circuit cut off relay (little white relay beside starter solenoid)..still could not pull start nor could i jump accross the solenoid to start (wasn't getting spark either way..so i replaced ignition coil (spark plug is new, i tried old plug as well)..still no changes..then i took off the start circuit cut off relay, using two jumper wires i completed that circuit with the relay out..kinda by accident i had unplugged the small red wire coming off the battery/fuse, at the bullet connector..now with the red wire disconnected, and kill switch bypassed, i could get it to crank at push button, but still no spark..but got it to start with pull cord..rode for 5 min, then it backfired, and the bike cut off on me, then it would start back up on its own (i guess because i was rolling pretty good).go for 10 yards, cut off, start back up on its own, 10 more yards cut off again.(by this time my speed was way down)...this time it just died and didn't start back up..let it sit a couple of minutes and finally got it to start with pull start..got it back home...after it cools down i can pull start it every time as long as that little red wire is disconnected, but it won't run for long, ( it will idle forever, but when i drive it and put a load on it, it will not run very long and it will cut off again..when i hook the red wire back up to use push button, i get no spark, but with that relay bypassed it will turn the starter, but no spark...i had inspected/cleaned all connectors, inspected all wiring i could( i pulled all tape off wiring harness and went over it)..i have been at this for a couple of weeks and am stumped at this point..i am gonna test my pick up coil later today ( i think i already tested it but i'm gonna test it again to be sure) and see if it is within spec..but i looked at the previous owners service records and in January of 2012 (one year and 9 months ago) he had the stator replaced at the dealer..so i'm thinking my stator is probably good, as well as the pick up coil, but you never know.. but i just don't know what else it could be..if my cdi was going bad, would i be able to pull start it and drive at all??.i read that when they go bad, they usually completely die. .disconnecting that red wire is the only way i can pull start it, hook red wire back up, and i get no spark either way (button or pull start)
can anyone give me some advice/guidance on what to check next??..i'm starting to believe it is a wiring issue, but i have looked and looked and cannot find any bad/loose connections or bare wire/wires, not to say i haven't overlooked something..someone told me it could be the voltage regulator/rectifier but i dont think that's it..i'm leaning towards stator/pick up coil.
in summary---
battery is at 13v when i charge it, then it will go down to 12.4 or so after i try turning the engine over..haven't tested under load..replacement battery is on the way in any case
spark plug is new (also tried old plug which was still good)
start circuit relay is bad, will replace asap, but can get starter to turn with relay bypassed with jumper wires and red wire coming off battery disconnected
can pull start with red wire disconnected, relay bypassed, but will not run long, as soon as it gets warm it will start shutting off..will idle fine..just when i put the engine under load is it shutting off)
also when i pull start, the neutral light is very faint (becuase red wire is disconnected)..but when i rev the engine, light gets even fainter
headlights also flicker/dim when i rev it up (again with red wire disconnected)
i believe i have kill switch bypassed properly..can't remember what wires connected, think it was a black/yellow stripe and red/white stripe)
I also have my parking brake safety/rev limiter out of the circuit..( i unplugged them then plugged the black wire into back/white wire at bullet connectors and disconnected the white plug coming off the parking brake if i rememeber correctly)
The only grounds i can find is the one coming off negative battery terminal, cleaned it, and the gound (black wire i believe) going onto the ignition coil, along with the orange wire..that ground appears to be good and is nice and tight
I pulled wiring harness and inspected every inch, found no issues
Any ideas, questions, concerns, or comments??
I have a multi meter so i can perform tests on wiring/electrical components..i also have an ammeter if needed..i just need some help on this
    • By Tim Keiper
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By fwsamm
    • By nlee
      Do any of you have ATV's for your children or grandchildren?   My grandboys are fairly responsible, but they ARE boys!  The ride the heck out of this 4 wheeler.  Any suggestions what I can do to keep it running longer....?
