Foreman exhaust?
JimmyTaylor
    • By Werewolf
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By mga
    • By Spritee1
      not sure where to look next
