Having trouble with rear brake. Removed caliber, plunger was stuck, freed, bled brake, doesnt appear to be any air in line, still no brakes. (question) is there a seperate master cylinder and/or reservoir for rear brake or is one for ft brake also one for rear. If there is a rear master cylinder i would say its bad causing no brake. It applies a little bit, but not enough to do any braking. tks
    • By Tim Keiper
    • By mga
      on my left brake handle (for the rear brakes) there's two wires attached to it. What are these wires for? They can't be for the tail light, since it only has on filament  I tried to trace them, but i got lost in the harness. I checked wiring schematics, but didn't see anything like that.
      I'll post a pic later.
    • By mga
      2000 Big Bear 4x4 400.
      do the front and rear drive shafts have to be lubricated? they have boots on them and i was wondering if i had to pull the boots off and grease the "U" joints? These are the ones close to the engine front and rear.
    • By motox88
