Motorcycle Fail Part 2
By Roofus
I cant seem to find what this part is called. Can anyone point me in the right direction? I must be misinterpereting the parts catalog or something? I dont see it in the rear axle section. I think it may be in the rear brake assembly section? click link to view picture.
[removed broken image]
By kiriyaaoi
By starsteven22
Anyone have a problem with the Polaris instrument cluster/speedometer frozen(part # 3280453) ? Mine is always showing R and slow now(see photo), Did it go bad or can you reset it or is something else the problem. It is on a 2004 Sportsman 500
By Ironworker709
I recently got a great deal on a 2001 Big Bear 400 4x4.it sat in a barn for 2 years while the guy was in college,so it need carb work...got it to use around the property,not racing or anything crazy with it
It runs GREAT and strong..no smoke or funny noises,just seems to have an issue at times ,when you hit the throttle it want's to die ,most of the time it runs strong.
So am debating a rebuild kit or new oem carb...i got to looking around really good yesterday and found this broke off..( the bent tube where the pencil is pointing).... is this a part that comes with a new carb?..if not,,where can i get the part?
I found a diagram online but it does not show the bent tube with a nut on it but says it a "Starter set" in the diagram(Number 21 in the diagram)
I checked the petcock and it is getting plenty of fuel flow..but it has the common drip leak..so i am ordering a new one,..was going to get the seal kit but for the price it is about the same price as a whole new petcock
Just trying to figure out where i can get this part for repair
By Krazo
2005 King Quad 700
Took off the front plastic and pressure washed it. unfortunately while doing this I lost the metal insert of a rubber grommet. There are 2 rubber grommets with inserts on the front, Left and Right. The screw that goes through here holds the front cargo rack on. Any ideas where I can find a replacement? id take the metal insert or a whole new rubber grommet with insert if I can find it. Pics are front and back of both grommets, one with the insert, one without the insert.
