d/l an owners manual and read up on the factory procedure. A leakdown test would give you a more accurate story about your internals. It will tell you weather its a piston ring or valves. 155 doesnt sound low to me but Im going by what passenger cars read. In a nutshell you would need to remove the cams and head and inspect valves. if ok then remove the cylinder and inspect the piston/rings.
    • By Trent Finnessey
    • By DZL1
      Thanks in advance.
    • By pastorjeep
