1994 bayou 400. regulator/rectifier got real hot to the touch melted one wire connection in plug.replaced stator and reg/rectifier runs fine but reg/rect is still hot and yellow wires from alternator are hot.any ideas what might be.:aargh:
They do run pretty hot. Make sure your battery is OK? Put a test meter across the battery terminals and check the charge rate is not over 14.5volts. Cheers
multimeter shows 12.7 - 12.9 volts. it will drop to 6-8 volts for a second sometimes.
Sounds OK, but it would be good to have battery load tested to make sure and then you are good to go.
The Reg/rectifier does get hot, that is how it cools itself. Just make sure you keep the fins clear of dirt etc so it can cool effectively and trouble free. Cheers.
well put on a new battery Saturday.been starting fine until today ..battery down enough it wont crank .there is no spark at all when you put cables on like there may be a short or something......:aargh:
now everthing on this piece of !@#$ has been replaced except cdi unit......I have checked all wiring many times...cant find short................................
OUCH! Can U unplug yellow wires to stator and check with ohmeter? Is there power to earth down through stator??
how do I check voltage out of alternator/3 yellow wires from alternator.should be around 60 volts?multimeter from yellow wires to ground? all 3 wires?
Unplug wires from alternator and start engine. test voltage out of each yellow wire-to ground- 60 volts minimum. yes.
turn engine off and check each yellow wire to ground with ohm meter. Should be no continuity to ground. no reading in ohms??
not grounded..but only 1-2 volts coming from alternator.I have been asking about the wires and regulaor getting real hot on 3 or 4 forums ,all said normal.the regulator plug was melted when I replaced it.pulled plug today from alternator its melted too.
I guess the stator I bought is bad.man I cant get a break on this money pit bike.:aargh:
sounds better. The hot melted plug still worries me though that it may have a short to ground somewhere??
Does the new multimeter read higher voltage at the battery now??
ill check battery tomorrow. I am going to check all wiring again this weekend.
    • By Travis_Smith
    • By KSIM
      View File CFMOTO C-Force 400 service manual
      C-Force 400
    • By Kawasakibayounospark
    • By neilroy87
    • By beast6228
