i put a higher compression piston in my 400ex and now when i drive it roughly every 30 seconds or so it dies down like it is out of gas then it picks back up again after about 5 seconds of that, i was wondering if the piston would require a bigger jet or could it be because i dident get it back in time just right?
ps. it has a pipe on it but im not sure if its full or slip on
well the thing about it is that it ran fine before i put the piston in it
U may have an airbox intake restriction as well or u might have accidently restricted the fuel line when u put it bak 2gether??
ill go look and see if i can find anything like that, do you think that carb cleaner would help?
    • By Trent Finnessey
    • By Dumass
