Hopefully someone here can help me out. I am getting ready to build a pulling tractor using an ATV engine and need some advice. These are garden tractors that are converted for pulling a sled just like the big tractors do.
The class I am interested in allows the use of an ATV/three wheeler engine. It can be up to 400cc, but has to be a single cylinder, four stroke engine. We are allowed to modify them, but they have to be run on gasoline, and are not allowed to use any form of supercharging or nitrous. We can start out with a smaller engine and use a big bore kit, but the final size must be 400 or less.
My question is, which engine would have the most power potential for something like this? I am not concerned about brand loyalty or anything like that.
Any help would be appreciated.
Thanks for the info. Is there any year or years that are better than others, or did these engines stay similar through the years?
EDIT:
This may sound like a dumb question, but I am not ATV savvy by any means. After researching, I see people referring to the DVX400 and KFX400 engines as being the same. I know Suzuki and Arctic Cat have relations, but is the Kawasaki KFX400 engine also the same? If so, it will make searching for a donor quad a little easier.
Chris
Edited by Chris65
Im not sure who built what for who. I would stick to the Suzuki motor unless you can find out who builds each others motor.
Im a Honda guy so hopefully a Suzuki expert can help you on years to get
Sent from my myTouch_4G_Slide using Xparent BlueTapatalk 2
Edited by marioweldinginc
It will probably be a while before I start this project, especially since I need to find a donor for the engine, but I will definitely document it. We are also planning a tractor build with a Vmax4 snowmobile engine for another class, and I am in the process of building a stock car for my friend's kid right now, so my plate is kinda full. We do document our builds of everything though, so I will share pics here when we get started.
    • By Panupong Pradchaphet
