Hey quadcrazy im looking into but a suzuki lt250r but the guy said the piston needs to be replaced and he said it wont start. He is sale it for $500 dollars. Ifi do replace the piston do you all think it will run or are there more problems with it you think ?
Also i would like to say thank you to everyone who has helped me on this website i greatly appreciate it one love
if you replace the piston, you will need to hone the cylinder out and take a micrometer reading. i know there are 3-4 different size pistons for the bike for honing and wear. you might have to adjust the valves after for it to start and /or carb work. thats all i have ... sounds like a pretty good deal btw ...
So its worth it ? and he did mention honing the cylinder i dont know about a micrometer reading but ill look it up and read and watch videos i appreciate the response greatly.
If he has a 88 LT250R than its a 2stroker Super easy to rebuild ! No valves involved !
yes, easy to rebuild. but there will be a lot more than just a piston. if it has such bad compression that it will not run, it will need to have the cylinder bored oversize to get the cylinder walls straight. one of the problems, is as the cylinder wears (along with the piston) is the walls become egg shaped (top to bottom). in part because of all the ports (holes in which the fuel/air/oil mix moves thru the engine). and as the piston wears, and gets quite loose, it actually rocks enough to have actual metal to metal contact with the cylinder wall. much more then when it is new, and tight. this allows for even more, accelerated wear. now, the big deal, is, the cylinder can only be bored so far oversize. after it gets so large, it either has to be replaced, or bored very over sized, and a new sleeve installed, which will in turn need to be bored to a new stock sized piston. you will also need to replace the top end connecting rod bearing and piston pin. those are very important, and wear about as fast as the piston does. and all of the top end gaskets. finally, the bottom connecting rod bearing, will only last so long. if it is loose enough that you can feel ANY up and down play in the rod on the crankshaft, then a new connecting rod, pin and bearing will need to be fitted as well. that is called rebuilding the crankshaft. all of this together, is an expensive proposition. but when you are done, you will have an engine that will last a long time. at least as long as you do not forget to mix oil in with the fuel. 1/2 of a tank of straight fuel will ruin the engine! to replace the connecting rod, the entire engine will need to be torn down. and at that point, EVERYTHING needs to be looked at. every gear in the transmission, water pump, etc. etc. etc.. hopefully, you will be able to simply rebuild the top end, and be done with it, for now. but all of this is coming eventually. i am not trying to scare you off. but you should be forewarned as to what will come along down the pike. or, it may need it when you buy it. there is no way of knowing, until the engine is opened up. id did this kind of work for roughly 35 years, until i screwed my back up so bad i can no longer work. so i have a darn good idea what i am talking about. oh, just as an added side kick, there ARE valves in this engine. they are REED valves, in the bottom of the intake port, that help feed extra fuel/air mix to the engine, for added performance. they will need to be looked at as well. if there is the TINIEST of cracks in them, they will need to be replaced.
    • By Tim Keiper
    • By Atomusthenes
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Tinkeringreg
    • By Mhatayas
