okay i have a yamaha warrior 350. when u turn ignition on the reverse light come on when u r in any gear and want shut off. cant figure out y? is there a reverse switch possibly that isnt plugged up that should be? any suggestions would be great thanks its driving me crazy!!!!!
there might be a short on that wire and making it stay on. Switch might be stuck also ... Your linkage is ok? You can shift alright in all gears?
yeah linkage checks out great and the shifter peg goes in all gears!! Could a short in my ignition switch cause this? Okay when i dis connect the ground wires on my ignition it still turns my motor ove and light is still lite up!! What could this be?
    • By fwsamm
    • By TravisM
      2001 bayou 220 KLF220A
      I'm at a loss here. Thanks.
