If its like my 400ex you pop out the axle. Remove the carrier. Pull the end seals off. Use a hammer and punch and push the bearings out from the opposite ends. Use a bearing installer to tap the new ones in.
Sent from my SGH-T989 using Xparent BlueTapatalk 2
    • By marcosphoto
    • By bigd764
      I went to NYC over the weekend to see the tree at Rockefeller with tha family, and on the way down from about 50 miles north could not help but keep looking in the sky while driving at diffent lights. Planes, small planes, choppers? Some of them looked like slow moving drones but not really sure. If you are in the tri-state area, you can't help but wonder what's going on... thoughts?
