Hey fellas,
posting from Western Australia.
Been on here a bit lurking and read alot about the Suzy ltf250-300 quadrunners.
Im building one out of two sh** boxs so i thought id put back in a bit and post some info on my build.
Ive got a late 90s 2504wd and a 982wd,both seen better days!
Frames rusted,cases corroded etc etc.
One had 20,000klms,the other 3000klms,picked them both up a while back for a project in the shed. The 2wd one with low miles had been used on salt lakes in the outback :(
Lower engine cases corroded badly. So i used the cases off the other one,they were sandblasted and the 2wd internals are like new so in they went after painting.
High comp piston arrived the other day so i"ll get it bored next and finish the motor off.
Started on frame the other day,replace all bottom rails and fronts where suspension bolts on with gal tubing.
Cheers Goldchaser
Will do,i"ll post some pics when i have more time.
The quad will be rebuilt top to bottom.
Plan is double A-arms at rear with 2 inch lift,hope to use Arctic cat rear cvs on it,1 inch spacers and 12 inch rims.
Oil cooler plus cooling fan,storage boxs etc and frame will be beefed up a bit as well.
I have a new Polaris 400 also,this is a build for the wife.
We use them for prospecting in the outback.
Edited by goldchasa
Welcome to the forum Aussie Guy !! :seeyac:
Man, sounds like you have one heck of a project bike go'in !! Look'in forward to see'in some photo's of how it's go'in ... :toetap05c:
Howdy Neighbour. Hope you are warm enuff over their.
A bit chilly here this mornin. 6 degrees. but will be a nice day, maybe 15.
Cheers!:ola:
    • By PIYIRIO
    • By gbanker
    • By Cyndi77
      Hello I just bought my son a 1998 kingquad 300. The brakes do not work but other than that we just want to learn all we can about it.  To keep it up and going.
