Hey I have a 2002 400ex I was riding it went mudding then on the way back home went through some water which was not that deep and when I got out of the water it cut off and wouldn't crank please help
if you have a voltage tester, you can see where the power stops. it wont crank, you mean the electric start or no spark? make sure the wires to the starter are good, unbolt the wires and clean the connection area(s) and then try ...
Make sure your air cleaner isnt clogged up and check your valve adjustments. Sometimes things happen at the exact time and it makes it seem like its related. If you feel its still an electrical problem dl a shop manual and check your connections like Oxy said. If still at a loss pm CK_1999. He is a wiz with the 400ex
Sent from my SGH-T989 using Xparent BlueTapatalk 2
    • By Dumass
    • By Trent Finnessey
    • By Arizona
