By jwh
I am new to this site. Now down to business, I have been given a Kawasaki 220, tires are trashed and it has been setting for a long time. Do I need a battery in it to find neutral? I know there is a neutral switch and if I shift down(7 times????) then up one using the neutral switch I should be in Neutral. As you see I am in a learning curve here ......coments welcome.
By mans
Were is the neutral safety switch on 03' Kodiak 400 4x4 . How xan i check it to see if it's good for a no neutral light no power to machine. Ty
By TimothyLindblom
Hi everyone, I’m new here and new to 4 wheelers. Just got a Yamaha bear tracker 250 and joined here to see if I could get some help.
The motor runs and it drives if it up on jackstands but if you get on and try to ride it, it starts to drive but then quits after a foot or two and dies out and won’t drive. The guy I got it from said he was running and using it shifting through all the gears great and he started it up the next day and it started this.
He told me he thought it was the U joint on the driveshaft. He said it was probably worn and needed to be replaced.
I just finished pulling the swing arm and rear end assembly to check out the U joint and there’s no play in it. It’s tight and not nearly enough play to be loose enough to not catch and go.
Any ideas on what it could actually be?
Timothy
By gt_jacket
Hi,
I have an 04 bear tracker, with a minor starting quirk. It starts in gear with brake in. Neutral and Reverse lights work.
But when trying to start in neutral, there is no click or attempt to start with the push button.
However if i pull up on the shifter (not hard enough to shift into first though) the neutral light goes off and the start button works and it starts fine.
All gears shift fine with no issues, has anyone seen this before? Just wondering if it is a bad sensor or something needs adjusting.
Thanks for any help you can provide.
By DaleJAM
